c-com screen printing
  • Thread starter Thread starter Blownvette
  • Start date Start date
B
Blownvette
Guest
How would I go about printing out a 3d table. I am currently using the DOS program.
There's no actual "print" function in this software, so here's a way to make it happen:
Start the C-Com program either from Windows, or at least with Windows running in the background. Open the screen you want to print and press the "Print Screen" key. This will copy the contents of the screen to the Windows clipboard. Go back to Windows, open up a bitmap editing program (even the Paintbrush program included with Windows will work) and paste the contents of the clipboard into a document. You can then print the image from here.
Craig
Yeah, you can also do <Ctrl> or <Alt> Print Screen (one of those 2, can't recall offhand which one) and it'll only grab the current window instead of the whole screen.
TurboTR
That is true for the Windows software, but not an issue for the DOS software. Thanks though... I forgot about that trick. I don't remember if it is ctrl or alt that makes that work either!
Craig
