Aren't all 109 blocks grooved from the factory? (it seems there was some sort of final machining differences with '86 .vs '87 in that regard)
the rule is you have to have a groove somewhere. It can be block, cam, or bearing. Personally I don't care for the grooved cam. To get oil to the other side it has to pass into the ID of the bearing, go back through the bearing (hemorrhages some through the bearing clearance) and what's left can feed the lifter rail. Not to mention having less load bearing area on the cam journal.
A groove going around the bearing offers a little more positive oil control and allows you to limit the amount of oil going to the front cam journal.
