Cranked the engine about 2 or 3 times then it fired right up.  Oil pressure was good at about 70 psi, then about 10 minutes in to the break-in the temp started climbing pretty fast.  I let the temp gauge go to about 220 degrees then shut in down, let it cool for about 15 minutes then restarted and broke it in for another 15 mins.  My question is would this hurt the camshaft from shutting it off then restarting it?  My cam is a 210/205 reed ruggles w/gm lifters.   Seems to run fine no missing or anything.  A little more noisy than I would like.
_______________________
1986 Buick T-type
.030 over / 210/205 cam, stock heads, turbo, intercooler,etc.
1986 Buick T-type
