- May 25, 2001
I'm going to be putting my econo-ported GN1's on soon and am thinking about changing the cam out while i'm at it.
I currently have a Isky 214/208 cam in the car and it seems to run good. (no solid track numbers yet, but it did run 115mph at 15psi). The heads I have on the car are stock.
Would it be worth any HP to go to a 218/218 to help take advantage of the better heads?
I want stay away from the roller due to the cost.
Also
What is the part number for the ARP studs for the GN1's?
What is the part number for the ARP rocker studs for the GN1's with scorpion roller rockers?
What headgasket is best to run (.030 over 109 block)?
Also
