trading t/a
I'm Angry!!!!!
- Aug 6, 2001
Wasn't going to change the cam on my current setup (only a few hundred miles on motor since complete rebuild) but some 87 octane slipped in while I wasn't watching and the first hint of boost was the straw that broke the camels back! Even 14 psi is too much apperently for 87 octane. Was goiung to E-town and needed just enough to get there to fill up with 112.I didn't know it was 87 until I found the reciept the next morning 1.89 seemed cheap for 93 octane I thought
Here's the plan: Heads going to Webber for an o-ring job, going back on with GM gaskets(recommended) and studs. A/c has been removed and heater only box installed, delete pulley on it's way, battery going to spare tire cubby and 8-point bar will be ordered shortly, Aeromotive A1000 external pump will be added also.
My combo:
SG1/109 block bored .030 fitted with GN J&E's(brings comp. to approx. 8.9to1 with TTA heads), TTA heads(ported, polished, big valves installed, valves unshrouded), Port matched intake(EGR milled and filled), Reconditioned rods with ARP rod cap bolts, Stock caps with ARP studs, modded front cover, MSD 50lb/hr injectors, Walbro 340 hotwired, Volt booster, Turbo tweak chip, stock maf, Billet afpr, ATR 3in. DP, 3in catback exhaust, Spohn LCA's and torque arm, Global west SFC's, SCanmaster, boost and knock gauges, CPT-65 BB(.63), 2500stall D5 12".
After researching cams from all manufacturers including 200/200 and 210/205 Lunati, 206/206 and 212/212 Comp, 208/208 and 214/214 Erson, and 204/214 Speed Pro, I've decided on the 212/206 webber cam with GM lifters and the above combo.
Has anyone ran this cam and what are your impressions of it......
My combo:
