SignUp Now!Postal... How heavy were your friends cars?
AKTURBOTA said:Frank,
How does your "big cam" idle? Who is the mfg? BTW how much of a difference did it make in performance?
Thank,
Mark
Hi Mark,
Sorry it took so long to get back to you, I've been away from the computer for 8 days. The cam idles and drives great, no problems. I have the idle set at 500 rpm's just like stock. I did advance the cam 4° for a better bottom end, it's a 112° cam. The original manufacturer is D. Elgin Racing Cams but this one was done by John Dougherty who used to work for Elgin but now has his own buisness. Well, as far as a comparrison of performance it is hard for me to give a solid answer since I have a lot more done to my motor than just the cam and I've had the cam for over 3 years and have made several other changes. Here's how I look at it; L. Conley used this came when Tweaked set the single turbo world record, he said it gave him 4 10th over the other cams he had tried so, in my view, it was the way I wanted to go.
Lunkan said:As I ran hyd.rollers on my TTA, I know they are longer. And all there is to do is get a pushrod checker to see what length the rods need to be. Nothing special about that.
89ICBM said:Here's how I look at it; L. Conley used this came when Tweaked set the single turbo world record, he said it gave him 4 10th over the other cams he had tried so, in my view, it was the way I wanted to go.
Hey! Think outside the box! I run a 276/270 and I love it!
Dan has gone on his own to open DLS. Dan optimizes cam grinds to his specs to better work with aftermarket Turbos, his stuff just works better than off the shelf grinds.
Ok I have a question now. I have the atr g roller cam in the tta I just bought. Has ported heads and the such. Where should I be shifting. As far as I know it still has the stock rods in it will they live to 5500?
Jason.. you need a running motor to use a cam .. Surej made me do it
I would spend the money on head work before I would a cam.
Funny how these cars dont care bout the cam..
are we really "splitting hairs" and it really doesn't make that much difference whether is is the 206/210 Austempter or the 210/210 DLS roller cam?
but going through the traps in 3rd gear at 112 to 114mph the rpms are again 5100-5200.
postal said:89ICBM:
I think you may be a little confused. I think you're confusing gross duration with .050" duration.
postal said:Nope! not confused at all! I just listed the advertised duration at 4000.
A CompCams 218/218 is 218 degrees at .050" and its 268 degrees gross. The cam you listed at 276/270 WOULD NOT idle at 500 rpms if those are the .050" specs. The .050" specs on your cam are probably in the high 2-teens to low 2-twenties if its an aggressive lobe cam like the Comps. If its not an aggressive ramp cam then the .050" specs are probably in the mid 2-teens or lower. Its really hard to tell how big a cam is by looking at gross duration.
The @ 0.050 for my cam is 230/224. It is a 112° cam with a 51° overlap. The lift at the lobes is 0.322/0.312 and I am running a custom roller rocker set up with a 1.6 ratio, heads were done by GTP. It idles at 500 just fine. TFTH!
