Cam sensor failure code showed up couple of weeks ago. I forget the number.
The car runs fine except I'm now getting knock at WOT. I was under the impression the car would not run with a bad cam sensor. Would this code show up if it was just out of adjustment? Would the cam sensor being bad or out of adjustment cause my knock?
DS shows O2's 780-800 and I've got the boost turned down to 18psi until I can figure it out. I'm running 93 octane from Mobil.
I've gotten a couple degrees of KR before but only when I get greedy with the boost.
Any input is appreciated. Thanks.
