I pulled the cam sensor out of my on center motor last night. The cam gear and the cam sensor gear are both worn to pretty close to knife edges. I've heard about this type of wear before. The motor has a production front cover with the balancer shimmed out to line up the pulleys.
I know the proper fix is to machine the front cover. When the front cover is machined does it completely take off the top dowel alignment tab ? Has anybody thought about shimming the cam gear out. It's going to put the gear over the end of the cam snout is the only problem there.
The motor has a Precision 236/236 solid roller cam.
Any ideas ?
Paul Thompson
Any ideas ?
Paul Thompson
