Hi guys, I usually always can figure out these cars issues but this one has me thrown for a loop!!
Here goes.. I cant get this car to act right at idle UNTIL I unplug the cam sensor then its bascally fine. The car revs up and down irratically and will stall half the time like the cam sensor is bad. I have put 4 perfectly working cam sensors directly out of good running cars and set them up perfectly 25 degrees ATDC and nothing... they all do the exact same thing as the previous one. I have moved them little in both directions and nothing really changes..car still stumlbes and wont idle right.
It runs pretty decent at WOT but it doesnt seem quite perfect.
I have had several differant crank sensors in the car with no differance and 2 diff ecms and 3 differant MAF sensors, several coil pack and modules also! Nothing changes...
Car has 55# injectors, 206/206 billet roller, ported big valve heads, ported intake. Car has run 10.60@130
Any solid ideas what to try or what to check next or where to go from here??
