I got the engine at 25 deg ATDC on #1 compression stroke.... dropped the cam sensor in....rigged battery up to 12v on the red wire.... ground on the black wire... and my multimeter up to battery ground... and the + on the multimeter to the blue wire on cam sensor...... no matter where I turn the sensor I don't get the 7.5 Volts like the "how-to" says....
I have double checked.... I'm getting 12v into the cam sensor plug at the red wire.... ground into the plug on the black wire.... and like .007 v out on the blue wire......
What gives....?
Any ideas?
What gives....?
Any ideas?
