I think I have it.....
I did adjust per the directions on GNTTYPE.... roll the sensor clockwise...then start rotating counterclokwise... until the voltage just drops off.... then lock it down.....
Engine should go in tomorrow.
I adjusted mine exactly the same way and it had a bad tip-in stumble.
Rotating another couple degrees counterclockwise cleaned it right up.
Just an FYI.
