Re: Reply
I will have to agree with Lou , but this will not fix the the problem just tell you if its the cam sensor the cause of the problem, if noise becomes less when you wedge the screw driver and put pressure on the cam sensor you know you need to replace gears on the bottom that means shimming the cam or just replace it with new one..
Originally posted by turbolou
All the suggertions listed here are good!But if all else fails I have tried this & has worked. Take a large screwdriver & wedge it between the cam sensor houseing & timing cover portion behind the water pump & ( gently ) pry it a bit with the engine idleing. See if this makes a difference.
