Cam sensor timing
Sorry nevermind...she's running better than ever now...I had it flooded with fuel so now it's all good. Gonna finish putting it back together and then I'm gonna take her for a spin. Hopefully she doesn't break down on me
Kick ass brother. Call me back after it's back together
Sent from my HTC6500LVW using TurboBuick Mobile mobile app
Freakin awesome!! Glad you stuck with it and finished it out! Another happy ending.
But I thank you all...I will only take half the credit! Thanks again everyone.. Now Danny is happy :)
Welp...I took her for a spin and it wouldn't go past 3200 rpm's...it would kinda backfire. There was also a weird ticking noise. No oil pressure light or anything and it fired up instantly. What could cause this. And once I shit the car off there is this really loud dripping sound that continued for a solid minute after I turned it off...any help? Did I screw somethig up..
Are you positive you were on the compression stroke #1 when you set the cam sensor?
Describe the dripping sound a little more.
Yes I re-did the cam setting 4 times because I thought a valve was still opened.. The dripping was just loud dropping sounds of liquid but it was outside so I couldn't see if anything was dripping. And all of my coolant disappeard although I did have a tiny tiny leak in the reservoir
Is there any way I can positively verify that I set it to #1 compression stroke?
And what could cause my car to not accelerate like that... It was at 3000-3200rpm's. my coolant was gone and my headers were smoking like crazy. (Valve cover gasket leaking oil)
Pop the #1 spark plug out and put a small wad of toilet paper in the spark plug hole (not all the way in the cylinder). When you get to the compression stroke, it'll blow it out.
So I have to take everything apart again (belts etc..)
No. Just pop out the #1 spark plug. Verify you're on the compression stroke, then verify your cam sensor setting isn't 180 out.
I was hoping its just burping the air out. This engine's not out of the woods yet :(
My thinking is that the engine hasn't been ran enough to tell is one plug has been steam cleaned (that's assuming the plugs are new after all the work)
I'm about to pull out all the plugs and no they were not new. Like I said..it was a moron that rebuilt my motor lol. Same plugs and wires..wouldn't be surprised if I have most of the same gaskets on there.
I'd pull the dipstick and check for milkshake.
I did and it looks the same color as the oil I put in there the other day before running it... How can I check if I have a blown head gasket. SloGN is also assisting me with this but I love everyone's help because I guess that's the only way ya learn right?
Also, I filled up my radiator with water and my reservoir with coolant, drove to o'reillys to get new plugs and when I was there I popped the hood and my water was low and ALL of my coolant was gone. So I filled it up and went back home... I did the same thing and again...all my coolant and some of the water was gone. Ughh
