Cam sensor timing
congrats on the fix.
I would add antifreeze to get closer to 50/50 antifreeze for the winter, and then back to water in the summer if it seems like it wants to run hot.
Bob
Oh good call but a member on here told me it is not necessary at all... I have a mice with alot of water an little bit of antifreeze in it right now..
Ummm...I've seen more than a few questionable recommendations from well known members on here.
Let's review shall we:
1 - You live in Michigan
2 - It can reach well below freezing in Michigan
3 - You have no real idea what your current mix is; i.e 50/50; 40/60 etc - or 5/95
For your area - I would not recommend going below 30/60 Ethylene Glycol to Water mixture
(See chart)
Conversely, you should not really go beyond 70/30 either
That is why the ole 50/50 is the oft used rule of thumb.
(See Bob's reply above)
You can easily measure your current specific gravity (or mixture ratio) using a common auto parts Hydrometer.
Again - I bet the parts stores have one to use if you don't wish to purchase
But do it!
Or your next new thread is going to be titled - 'HELP - Freeze plugs blown out - Coolant leaked out!"
Hello...McFly!!!
I guess I think outside of the box. If it were me, I would get one of those cheap $1 testers from Wally*Mart and test the current coolant. If the freeze protection is colder than ambiant at night, I'll watch porn and worry about something else.
If it gets colder than the tester indicates, I'd add some antifreeze then go watch porn and not worry about it.
He can do the antifreeze thing, but not porn since his parents is watching his moves;)
Thanks guys
Lol no need for porn I have a girlfriend ;)
I'm be safe and run the 50/50 mix although its really not that cold yet
Thanks guys
Famous last words - "yet".
I gotta go look at those cheap $1 testers at WallyWorld.
Are they test strips - also near the pregnancy tests - Aisle 25?
I always used the tried n true Hydrometer.
Technology - ain't it wonderful.
No, there's like small turkey basters with floating balls that indicate the freeze level.
Looks like the price went up a couple 'o clams since I bought mine. Still cheeper than a block.
Lol what would you guys run coolant wise..I know it's ultimately my decision but I just wanna know what u guys would personally run
Considering the temp in the Detroit area(winters get below freezing with ease)
any brand of antifreeze is good danny . just buy a gallon of the pure antifreeze and mix it yourself. when buying the premix 50/50 it's the same price and its half water........
Well when it gets cold I think I'm gonna get the 50/50 but for right now it runs awesome with mostly water
It barely blows hot hair through the vents...but I think my valve covers are leaking and dropping down the back side of the block u get the turbo, it's dripping down onto me crossover and burns it she to the heat and it smokes only when hot
This weekend check all bolts and clamps, , oil pan, timing cover, and the water pump. Install new spark plugs. The
Investment in a scanmaster will increase the life span of your engine also. Goodluck ! Call me if you have any other issues. :cool:
Sent from my SPH-L900 using TurboBuick Mobile mobile app
LOL - yeah 50/50 mix is for suckas.
Corporations - they will figure out every angle to rip people off.
Any brand of regular anti freeze (green)
I avoid Dex Cool and other similar voodoo potions.
Hey - my kids came from a turkey baster - or at least that's my story. :D
I really hate to admit I actually resided in the same bedroom with "that woman"
Good to see that Walmart dumbed down a standard Hydrometer - for their target market to be able to understand.
I don't know why they just didn't use icons, like smiley face, frowny face to indicate proper mix.
Or letters A thru F. Not that many of their customers would understand what "A" meant though.
