Cam Sensor
hensleyt
Will miss adjusted cam sensor make the car lazy off the line?
Runs and starts no miss fire just lazy 2.6 60 foot was 1.6
A cam sensor adjustment may improve performance with an advanced a small amount with a 210 cam and well flowing heads.
Thanks I hade it out to inspect the oil pump drive pen
Reinstall grab my Caspers tool,set as always .Car is lazy and 0/2s rich at just leaving the stop sign.at the racetrack my 60 was way off but trapped 114 as it should. Just did two passes laptop would not stay connected so no data.no KR on scanmaster
Wastegate not sealing right, leak in vac reference line to wastegate or leak in exhaust pre-turbo?
Ya just went down that road ,got the over boost under control all was good.It ran good tell I had to swoop lifters and I pulled the cam sensor
I can build 5 lb on the line ,but let go of the break and it just moves out so slow then maybe two cars out it takes off.
It put up a good mph 80 mph at the 1/8 normally 82 and 114 at the 1/4 where it normally is, ET way off 13.5 normally 11.9
