cam specs suggestion ?
krawczuk
hi, i have built up a turbocharged vn v6 auto holden commodore, the engine is pretty well based on the buick v6.
it is nearly all done, all i need now is a decent cam to suit the turbo engine, any one suggest some specs for the cam ? i will mainly be using it at the strip.
at the moment it has the factory hydraulic roller cam in it.
details of engine .:
v6 3.8 ltr
std pistons
std valves
ported heads, inlet manifold.
8.3:1 comp
85 lb holley injectors
microtech efi computer
auto trans 4l60 with 3000 rpm high stall
3.08 gears
super t70 turbo 16-18 lb boost
70 mm throttle body
intercooler
thanks,
mark k
