Does the TA block use the same bearing bore location? Changing one aspect will snow ball everything. The geometry will change. Just raising the cam bore a little has a huge effect on the cam journal size potential which will allow the use of the correct masters for the aggressive lobes. Turbo guys will need a core with typically a 112-114 LS. The cores could be made with 112-113 and likely be ground to have a couple degrees either way. Raising it will give an advantage for sure on applications that want to squeeze the most out of their combos.
