SignUp Now!It's an 87 FWD block. I think I'm gonna go with the Edelbrock cam. 204/214. I will get the head #'s from it tonight.
I hate to say it but you're right. The intake lines up purfectly to the heads except for the coolant lines.The're too big and go outside the intake boundarises.
O well looks like I'm off to pick and pull to get some heads. Their is a 3.8 with a dualjet there. They should be the right heads. I will probably need to get the valve covers too.
Their is another problem tho. I won't be able to use the headers either as the bolt pattern on the SFI heads is diffewrent for the exhaust manifold. @#&$ I'm starting to get pissed here. I think I'm gonna have to get the head coolant passages filled in or add extra material to the intake.
Before you go any further you need to take the heads and physically put them on the block and then see if the intake lines up on both heads. The first FWD 3.8 was off center and the only other diff from RWD was the bellhousing and the flexplate mounting flange. It's smaller. The second FWD engine GM changed the block to center the rods better on the crank, hence on center. I think you have an on center not an off center. I may be wrong but....?
