ek02
- Jan 31, 2008
Both those cams are Turbo cams. You can order a custom roller from Comp and they will grind it to the same specs as any of their flat tappet N/A cams. The lobes will be shaped differently than the same flat tappet grind, but the duration and lift will be the same. A roller cam has a more rounded lobe instead of coming to a point. The advantage is that it pops the valve open and closed faster. I have a flat tappet and a roller, both with the exact same specs. When you bump the engine over you can see how much faster the roller opens and closes the valves. That's why I think a roller usually develops more power. The Comp 980 springs will not be strong enough for a roller. You would need the Comp beehives. 26915-12 for a mild cam and 26918-12 if you go a little more radical. Or, you can search valve springs on this forum and come up with other companys that sell good springs for a roller. For the grind Comp recommended I would use the 26915-12's. It's only .425 lift. I run the 26918-12 springs with 5.25 lift on a roller and spin it to 6500 RPM with no problem.
