I need to know where to set the cam sync on a classic FAST system.I have the crank trigger set at 50*btdc and rolled the motor to 25* and aligned the rotor on the dist with the #1 cylinder.Does the cam sync come in before the crank trigger signal at 50* or before the #1 firing? Thanks Chris
