Cam
setup
*50# inj
*T61 turbo
*3200 stall, 9 inch
*razor alky
*70ml TB & DH
*4inch down pipe
*turbonetics external racegate
*single shot exhaust
*3.5 maf translator
*Large Front mount
*walboro 340
*rjc power plate
Plan on having heads ported & upgrading valve springs
If you decide roller....I have a never been run Comp XR2 hyd roller cam (cam only) forsale in the Parts for sale section.... :biggrin:
210/215 @ 0.050
.516/.516 lift with stock ratio rockers...
110 LS
Anything wrong with yours? If not they are good for 10-11 sec easily. These cars are not real cam sensitive.
if the stock cam is ok use it. if its trash you can go with a nice 206/206. that should work well for you
I second the 206/206,only I choose it over the stock cam.
The 206/206 makes great torque in a 3.8 and will give you a few hundred RPM more pull.
I say do the cam. Roller isn't going to make much differnce in power at your level and you could use the extra money for other things IMHO.
*50# inj
*T61 turbo
*3200 stall, 9 inch
*razor alky
*70ml TB & DH
*4inch down pipe
*3.5 maf translator
*Large Front mount
*walboro 340
*rjc power plate
I would'nt do the cam, untill you do the heads.
IF you do it, the 206 isnt bad but I prefer the Erson 208 or go 214 for a little extra kick!
if the cam is fine then why mess with it :confused: leave it alone and get the car running :p
My experiance with roller, is if you recam, go roller.
Rollers are expensive, however, no hi rpm break in & no zddp.
We used to turn new rebuilt roller cam aircraft engines at about 250 rpm over an hour - used an electric motor to turn it.
Either keep what you now have or go roller - nothing about these TRs can in any way be considered cheap.
