That is a lot but as long as you have plenty of thread engagement it shouldnt matter. I will confess I personally have never used one of those shafts though. If there are threads past the bolt and the car drove nice, i would let it ride. If your shooting for more negative camber for some kind of track racing then I would get it on the machine and start by adjusting the shaft with a few shims. Then remove or add to dial it in where you want. Set the specs in the machine to what you want, and it should get you very close.
Sent from my VS990 using Tapatalk
