Cammed '94 Trans Am GT
E-bay fell through
1994 Pontiac Trans Am GT, Red paint a little more than 2yrs old, Gray Leather Interior, 6spd Manual, T-Tops, about 127,000 miles.
Hooker Headers
Hooker Catback Exhaust
Stage 8 locking header bolts
QTP Electric Cutout
3” Eastern Catalytic Converter (not installed)
Moroso Cold Air Intake
1LE elbow
CVR Electric Waterpump
Brand new OPTI
Welded Subframe Connectors
Lakewood Lower Control Arms
Welded LCA brackets
Panhard Bar
Strut Tower Brace
Monroe R/T shocks
DMS Springs
Poly End Links
New Ball Joints
Black Corvette ZR-1 wheels w/ polished lip 17x9.5
Auburn Pro Posi
4:10 GM Motive Gears
T/A Girdle w/ Stud Kit
Comp Cams CC306 Cam
Crane Gold 1.6 Ratio Rocker Arms
CM-612 Valve Springs
Comp Lifters
Stock Hardened Pushrods
All New Gaskets (oil pan, front main, rear main, intake, opti seal)
Brand new Stock Timing Chain
Bosch 36# Injectors
Spec Stage II Clutch
Resurfaced Flywheel
Slp Short Shifter, Short Stick, and Hurst Shift Knob
Poly Transmission Mount
Replaced Clutch Master Cylinder and Slave Cylinder
Madz28 Tune
LT4 Knock Module
Some other things that were done within the last few thousand miles...battery, belt, wheel bearings, window motors, LS1 console, alignment, hatch struts, fuel filter, thermostat(160 degree), tranny fluid changed.
$7,600 obo
Located in Canton, GA
Nick.McCardle@gmail.com
