Can anyone help me ?
tgmanagement
I need help with my motor. I cannot get it to start or run. I am getting fuel to my fuel lines and fuel injectors and spark to my plugs but i used a noid light and im not getting any pulse to my injectors. I have bought a new ecm but still nothing. it starts if i spray starting fluid into my intake manifold though. Could it be a ground problem ? does anyone know where the grounds are ?
THe grounds are all on the passenger side cylinder head. (on the back of the head, and in a REAL bad spot).
The crank sensor, or cam sensor may be bad. Where do you live? We can suggest some one local to help you.
I had that prob....
I just drove around with a few cases of starting fluid and sprayed it into a long 4" irrigation hose that went out the pass. window into the engine bay. Worked great!
Ran 13.5@105 that way.
