Can Drum of Meth go bad?
Hyboost4Banger
Trannybreaker to be
If a 55 gallon metal drum of meth sits for one year unused can it deteriorate?
Thinking about stocking up. Mark
It can absorb water via condensation.
Not sure if that's considered going bad or not.
A chamois will absorb the water and pass the alky. Allegedly....
Got that from reading about it, never tried the stuff. :p
I bet it works as I saw a team due this at the Nitro wars a while back (pro mod car on Meth) and they stuck a Chamois in the funnl to I guess absorb water :rolleyes:
If your using the stuff in an alky kit the small amount of water that is in it I should think wouldnt be an issue but hay I am no expert :tongue:
Store it off the ground. That will prevent moisture.
Unless it physically changes color, if its clear.. its good ;)
