Can I go mid 11's with a te44 turbo?
cam
i see a lot people saying leave the cam alone and i agree if you don't have money for a roller. i stayed with the stock cam for years but if i knew i could have had the pull it has now up top i would have got a roller a long time ago. a cam would just make it a little easier to meet your goal but not needed at this point...hth...........Bob
It has the hot wire kit,adjustable fpr and I'm putting 42lbs injectors and a ported t/b in.I also have front and rear drag shocks along with boxed arms.I'm thinking on a small cam to go along with it?
These injectors are a perfect match for your combination & there is NO reason to go larger. Put it together, tune it & enjoy your mid 11 sec ride. :D
If it were mine i would add the RJC boost controller to aid with spoolup & install a Razor's Alky kit to have 11 sec power everyday on pump gas.
