can I keep dry sump
  • Thread starter Thread starter dem274
  • Start date Start date
D
dem274
Guest
I have a 274 bush motor with dry sump . I was wondering If I can
use the dry sump and oil pan in my t-type with out any inteferance . if possible can I run my acceseries like power steering and a/c and my alternator with out duttwieler front cover
and oilling system, because the dry sump is the best oiling system and it looks tough , it will save me money on the convertion . do I have to remove the stock heater box to run the stage heads and if so how do you guys run a/c on the stage headed motor , I also have an extra set of stage heads laying around with spray bar valve covers if any body is intersted.
Dry sump/stock frame?/
Lots of work! Looked into it and found the pump has to be moved up, the pump drive has to be changed, the pan may/may not clear the frame.
The A/C does not have to be removed. Use the ATR box mod...;)
