Can someone reveiw this power logger file?
DOUGGN
I just got my car going again with Razors Alky kit and the power logger installed. Made a 0 to 95 mph run. Can you guys take a look and see if you see anything I should be concerned with. Looks like I was running around 21 - 22 psi with no knock. Should I turn it up further?
It looks pretty good to me. I'm surprised your IDC is so low, not that it's a bad thing. Also I would upgrade to a wideband.
Boost and maf look choppy. Wonder whats up with that.
That what I'm kinda hoping you guys that know these cars can tell me. I don't want to break anything - but I would like it to run the best it can. Thanks for the help so far.
Injector Duty Cycle - I just figured with the bigger injectors it didn't have to work so hard! Is it because it is being supplemented by the Alky???
Any recommendations on a wideband? What does it involve to change? How much $$$? thanks.
A wideband 02 is something you add to better monitor afr's. PLX is pretty popular.
What kind of boost control are you using?
RL
Something else that came to mind. In some cases alky pumps can cause noise in the electronics. For chits and giggles try moving the alky power to a different spot on the fuse panel.
RL
RL
This would be to cure the choppy boost and MAF?
