There are or was two plastic pieces the size of a quarter that had notches in them. It goes on both sides and the notches fit into the holes on the mount.
So the plastic pieces must have blew off when it got hit? Any thoughts on a solution? Maybe short screws? They don't make them anymore from what I've found.
Either find your self some strong plastic washers and cut them to fit or get yourself some metal washers and machine notches into them so they slide into the bracket. Then paint plack.
I wouldn't use short screws, you'd be inviting condensation into the gauge itself. do what trixdout said or a strong adhesive if you can stomach it. Or get flashy with...see picture.
