Jun 23, 2003 #1 C Cale22 Doh! Joined Feb 12, 2002 Messages 443 Can a sticky 1-2 valve cause the 1-2 clutch band to wear out? If/so, how do I tell if its completely gone, or just a little worn?
Jun 24, 2003 #2 H HOTTOGO Never Enough!!! Joined Apr 6, 2002 Messages 964 a worn band is basically a dead band, you can shim the servo pin, but is pretty much a band-aid and can make it worse if you don't get it right on.
Jun 24, 2003 #3 C Cale22 Doh! Joined Feb 12, 2002 Messages 443 Thanks Mark. Does it mean that my band is worn if there is black soot on the bottom of my pan? Also, is there a difference between the BQ governor and a BRF governor?
