BullseyePower
- Jan 25, 2007
They are T-6 actually!!!!
SignUp Now!I'm sure T-6 would fall in to the add #100 class. However, we have some of the same class limitations in import street so we machine down the inlet to a T-4 size. Its T-4 all the way, however if they pull off your turbo for inspection they would still see the T-6 volute size.
The flange size would be T-4 but the volute would still be a T-6 so the HP and flow would be higher than an out of the box T-4 housing.
john, hello thats what im doing with my combo going to try the 88mm in 95 housing and dyno both ways with 95mm wheel to.That sounds interesting....
What do you guys do with a ET 88MM wheel?
Dave or Dan, what size turbo or turbos was the running.do have any pics.......Here's some 6 second 4 and 6 cylinders running the BorgWarner Extended Tip turbos. Vinny Ten and Brent Rau Videos
Here's some 6 second 4 and 6 cylinders running the BorgWarner Extended Tip turbos. Vinny Ten and Brent Rau Videos[/QUOT Got a new pic of the mounting of the turbo you want me to send it to ya .
sh-t my bad........Im just getting excited.
Are you sure you dont mean T-6 is the biggest, like the Thumper series turbos? I have never seen a T-5 header or turbine housing.
