toomanymodz
- Oct 14, 2009
I'm posting this for a friend since he's not on this site.
He's got an 87 GN setup. Mostly stock except for a turbo, cam, downpipe, hotwire and Walbro pump. He's running a TA performance 208/208 cam and a small stock-appearing turbo (he doesn't know the specs).
The car has no throttle response at low speeds and takes quite a few seconds to build boost. Once it builds boost it holds steady at around 13 to 14psi and pulls nice. He let me drive it and I tried to brake boost it. I could floor the gas while holding the brake and it wouldn't build boost. The RPM's would only go up to about 2100. The stall converter is a Pat's 2800.
We did all of the basic checks: fuel pressure, TPS volts, IAC counts. All look good. The idle vacuum is about 15 inches and the needle bounces slightly, maybe an 1/8 inch (that worries me a bit).
Another thing is the engine has never idled smooth. It sounds more like a V8 with a cam. Slight rough idle, almost like he's running a 224/224 or something.
He's had two different turbos on it, and has pulled the front cover to double check the timing chain.
He called a perf shop in Orlando and they want $1500 to degree in his cam, or $3k to throw in a roller cam. My friend doesn't have that kind of cash.
I'm not sure what to tell him at this point. Any ideas???
