Some of you may have seen my other post about getting rid of the power master. I finally have everything together and got the rear wheel cylinders bled last night. Had a buddy come over to bleed the fronts and the passenger side seems to bleed fine, but drivers keeps getting air. Pedal goes to the floor, and while in the wheel well I can actually hear the air in the lines. I have a line lock that seems like its seeping some fluid, so I need to bypass that, but it seems like if that was bad, I'd be getting air bubbles out the passenger caliper as well.
