The tech at Wilwood gave me this #: 260-8556
1.12 bore. 3.22 to 3.40 mount hole centerline. He said this is what you want for a HB app.
He also said if I had rear drums, to use a 10# residual pressure valve in the rear line. It's to be mounted not more than 12" from the MC.
The MC and the residual valve came from BCI, here in Atlanta.
The HB came from Elliott Sydnam, in Dallas, TX. [
sterlingworth16@yahoo.com]. He makes custom mounts for new HB units. Mine is inverted, & bolts directly to the firewall, so the accumulator is to the dr side fender. [Keeps it away from the LS coils.] $414.00 shipped.
Elliott also recommends a return line filter.
Cardone pt # 20-0038F is about $20, uses a cleanable filter. The NAPA # is 81-0589F.
I got the banjo fittings from Pure Choice Motorsports, in AZ.
I have this same HB on my 55. I couldn't get it to stop for
.[Only had about 7-800psi at the rotor. Added the HB, now have 2100psi! This MOFO will stop!
I also use the Wilwood adj prop valve on all my stuff.
I'll post some pics when it's done.
