paintitblack
- Feb 9, 2009
I can't seem to lower the boost. Let me start from the beginning and tell you what I have done because I am stumped. After the car sat for 8 years I bought a complete intercooled motor from a friend and got the car running. It had hooker headers, 3in downpipe with a deltagate, turbonetics boost controller, and I had it running with a open dump (didn't have the money for a full exhaust yet). Everything ran fine with no problems. Went to the track and had a transmission problem and had to pull the pan. Thats a different story, but I had to pull the crossover pipe to get the pan off which is a pain in the ass with the hooker headers. It ran a 13.30 in the 1/4 killing the street tires to the 60 ft. After that and the ride home with the open dump I decided I was putting stock headers, crossover, and full exhaust on. I ordered the T/A stainless stock replacement header kit, 3in testpipe with dump, and a hooker 2 1/2 dual kit ( aero muffs ). Put everything on and the car seemed to run way better but would over boost. Not changing the controller (set at 17psi) it would go way above 25psi. Turned the dial all the way down and would still go really high. So I removed the controller and disconnected the vent side of the wastegate to get the base line or spring pressure, which was 10psi before. It still climbed high. I figured it was the wastegate, and wanting to replace the old rusty downpipe I ordered a gn1 3in downpipe with a 46mm external gate. Before putting it on I ported the exhaust housing on the turbo to match the wastegate pipe so there was no question there. Put the controller on with fresh vac lines and all the way open and there was no change. Pulled the controller off like before and no change. So I then checked the line from the compressor housing to make sure it wasn't plugged and it was fine, but to be sure I ran it from vacuum block on the intake to the wastegate and no change. Then I called gn1 to find out the spring pressure and they said it should open at 8psi. From there I hooked up an air line with a ball valve and a gage to the wastegate to make sure the valve opened correctly. It opened at about 9 1/2- 10 psi. Running out of ideas I went through everything I changed and decided to run the car with the cutout open to eliminate the catback, still no change. Also when I go WOT from idle it kind of bucks or pops like the gate is opening then closing, opening then closing then runs up through the rpms normal. That happened with both gates after changing the pipes. The car runs fine and strong otherwise with no codes and problems as long as I roll into the throttle and don't go farther than 3/4 petal. I'm out of ideas and dont want scatter my motor all over the road. I plan on putting the engine on race fuel when I go to the track but I dont want to run it on the street, not to mention I should be able to control the boost pressure anyways. Sorry this was so long but I wanted to get all the info out. I cant do anything right now because it's put away for the crappy Ohio weather but it's weighing on my mind pretty heavy. Any ideas will be greatly appreciated. Thanks, Brian.
