robzombie
- Oct 10, 2012
The heat burns the moisture out that is already there in the system and what is drawn in from sitting.
Metal is like a sponge and absorbs water and the heat process removes it. The longer it sits the more moisture is in the metal and E85 is a water whore which only introduces more moisture into the system.
So there is a potential for rust in the cylinders contrary to what you say. Just look at the rust on the spark plug pic and there's all the proof you need.
