Captain Mark
- Oct 28, 2002
Just for the record. Things look like they are moving in the right direction!
Details of the run:
60' 1.70
330' 4.81
1/8 7.58
MPH 92.23
1000'
1/4
MPH
Captain Mark - TTA #797
EMPTY WEIGHT: stock
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION: Rebuilt by Rock-On transmission
TORQUE CONVERTER:3200 Vigilante
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:Yes
INJECTORS:38#
THERMOSTAT:160
TURBOCHARGER:GT 3255
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:ATR
EXHAUST:ATR
FUEL PUMP:Walbro 340
FUEL PRESSURE REGULATOR:Yes
FUEL PRESSURE:46 psi
ALCHOHOL INJECTION:No
PROPAIN INJECTION:No
NITROUS:No
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE:Nitto 555R 17 psi
AIR BAG(s):No
SUSPENSION:Hotchkiss control arms and panhard bar
SCAN TOOL:Yes
FUEL:104 octane
CHIP:Billy Duke
CHIP TIMING:21
KNOCK RETARD:None
OXYGEN SENSOR VOLTAGE:780
EXHAUST GAS TEMPERATURE:
TRACK ELEVATION:600 ft
TEMPERATURE:64 degrees
PEAK BOOST:21 psi
BOOST AT LAUNCH:7 psi
MILES ON THE CAR/ENGINE:44,000
Details of the run:
60' 1.70
330' 4.81
1/8 7.58
MPH 92.23
1000'
1/4
MPH
EMPTY WEIGHT: stock
BLOCK:stock
HEADS:stock
CAM:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:Yes
INJECTORS:38#
THERMOSTAT:160
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:ATR
EXHAUST:ATR
NITROUS:No
AIR BAG(s):No
SCAN TOOL:Yes
FUEL:104 octane
CHIP:Billy Duke
CHIP TIMING:21
KNOCK RETARD:None
PEAK BOOST:21 psi
