I was turning on to the highway and the car just died. This is the first time this has ever happened. I tried to restart it and it cranks fine but won't start. When I turn the key to run the Scanmaster usually starts showing sensor readings. Now, it comes on, shows SCN 2.2 then PL then goes blank for a few seconds before showing 6 dashes --- ---.
I recently did a vacuum brake conversion on the car and moved a lot of wiring around under the dash. I also swapped to a TE-61 turbo over the weekend. I would suspect I pulled a wire or something while doing the brake change but as far as I know it could be as simple as a blown fuse.
Could anyone point me in the right direction on where to start looking? This is my only car and daily driver. I need to get her back on the road asap.
Thanks as always!
Bill
Thanks as always!
Bill
