car dies,check engine light on,,,hard acceleration
TURBOTERRORV6
The Street killer V6
car dies after hard acceleration,drives kind of fat,,did improve a little by changing to a new maf sensor,but it still drives kind of rough(fat),and the check engine light flickers now and then. could it be the tps sensor?? while scanning for codes,i did get 5 codes,2 for the maf sensor(replace that) 2 codes for the oxygen sensor(lean) figure it was because of the bad maf sensor,and another code being the ("TPS open?)....need input my fellow buickbrothers,thanks
Offhand, TPS open suggests the TPS sensor is failing.
What are the exact trouble codes you are getting?
Mike Licht said:
sounds like the positive battery cable to me
Mike
well it when i hook it up to the snap on diagnostic,it read "tps open range" i will hook the diagnostic back again,and get the exact read.Also while im going @ 50mph,stomp the gas pedal,and pick boost up to 10lb,the volt dummy light flickers now and then???i have replace the following>>.220 amp. alternator,optima battery,maf sensor,,air/idle sensor....i have not change the o2 sensors,knock sensor,MAP sensor,or tps sensor............thanks again for the quick input,,,,
