The Darkside
Heavy Metal Thunder
- May 25, 2001
Ok,I got my scan tool working again & decided to do some tuning.I punched it from about a 35 mph roll,Here's some of what I'm running & some #s that I got.
Chip: Jim Testa 93 street for 009's
Fuel Pressure:set @ 43 line off
boost: maxed out @ 23lbs.
02's started around 890,went down to around 835
Knock:0 through out run
Spark plugs:Atuolite 23's,gapped @ .035
SMC setting:15 turn on,pump speed 8,100% denatured
See sig below to see what else I've got on car.
Problem:Car was really slowing up & nosing over at the top of 3rd gear!!!Felt like it might be bogging or something.
Possible fixes:
Lower fuel pressure to lower o2's?
Raise boost 1 or 2 lbs?
Lower pump speed?
Combination of the above?
Suggestions????
The Darkside
Possible fixes:
Lower pump speed?
Suggestions????
The Darkside
