scojack_2001
Livin' Like A Refugee
- May 24, 2001
Thanks. Did it say specifically for turbo Buicks to advance it?
One thing I did want to point out, is when racing it, it does seem as some of you have said, the car noses over at the top of the gear. In fact (and I know this is a bad thing) but I think (before I knew better) when I ran my best pass, I actually had it in OD so it hit 4th before the traps.
In fact, this thing does pull like a mule well into the 4k rpm range. Reviewing my powerlogger files I've gotten into the 5k rpm range.
Another thing I have considered trying...and I don't know if this would help...I have read most of you run a 28 inch tall tire at the strip...my rear tires are 26's. I've wondered if I threw a 28" tall tire on if it would perhaps keep the engine in it's power band a little longer and maybe would result in a better time? Anyone going to KCIR tomorrow want to bring some 275/60's?
I'll definitely check out the cam and valve train as suggested, but I really am starting to wonder if since the cam was advanced 4 degrees, if it's just running out of steam earlier than it would if it were installed straight up.
Razor I'm going to look into the air filter as you suggested.
All I know, on my GN; the 28s helped alot. At the beginning of the season, my car was running pretty consistently in the 11.7 range on a 26" tire. But the trap speed always seemed low, it was always around 113-114. I put some 275/60/15 MT DRs on it and the first pass next time out was a 11.42 at 117mph. Im assuming i still have a original untouched longblock ( except for springs & a chain), so I would drive way past the stock cam when I ran it. I would trap at 55-5600rpm on the 26s.
So I'd try a set of 28s and see what happens.
how do you figure your powerband stops at 5k?
Mine used to do that, you can drive past the cam and go out of its powerband.
Actually I think I am going to try to go to the one next Sat, the 26th.
I don't know, I am going off of speculation based off of the butt dyno.
They're stock casting heads, but I don't know if they've been ported or anything like that.
Im running almost 30psi through my stock heads. As long as it doesn't detonate it will be okay. My TT chip is burned for 23-25psi.
