dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
How's your fuel pressure ?
SignUp Now!Have you put a little oil in the bores and see if it comes up? Easy way to see if its the rings.
Sent from my LG-C800 using TurboBuick Mobile mobile app
Try letting it go into od and see if some of the mph comes back
do a leak down test rings are gone
I've had engines that had compression variances like yours, 30% leakage, etc and it doesn't matter. Fixing them fixed those issues but the power was the same
Okay your base fuel pressure is good have you verified that it raises 1 for 1 and it is steady at all boost levels ?
more than 50 percent is it pushing oil into the breathers
if he looking for mph i would verify timing
how about a running compression test if you don't have a leak down tester
increase in compression with oil
IMO it's worth it to get the converter nailed down. Also worth it to pull and verify a couple valve springs.
