The car is stock, except with the addition of an Alky kit, a Pit Bull, and some exhaust work. It has an adj. wastegate and FP regulator as well. I can stomp on it, and the car pulls well to 10# but anything above that it runs better if I back off the throttle. This happens both with and without the alky. At part throttle when the alky turns on (10#) the car pulls hard. IMO it seems like a lack of fuel, and at WOT it's not getting enough fuel to match air flow. O2 readings are useless on the t-link, they bounce from double digits (like 23) to around 750 and everything in between. Fuell pressure was set for the chip by previous owner (at 45 I believe) but I have a guage on its way. Pump is new stock with hot wire kit. Even with the SMC pump speed at 10 at WOT it still runs better when I back off the throttle a bit. Any other thoughts on this? No codes either.
