SignUp Now!after market on hose, the throttle goes all the way back to torx screw, and I pressed on throttle didn't move anyIt could have. The IAC could have carbon on the pintle and/or seat that lets extra air in. The cruise control cable can be too tight not letting the throttle close the entire way too.
Do you have a stock flex MAF hose with a hole in it or an aftermarket solid one?
so I need new iac if I plug hole and it don't run<and do I need a new tps?? the tps got a bath to..If you had the IAC in the throttle body when u washed it consider it dead now.. Try putting a plastic plug in the IAC hole, it shouldn't idle at all. Or you have a huge vacuum leak like PVC valve disconnected?
Thank you Ill order them tomorrow.Oh boy! Yes TPS also...if you plug it and it doesn't run that means the IAC is bad..hope this helps.
