Temp gauge shows 200 when it used to always show 180. The fans come on for a brief time to maintain it at 200 then shut off. Now if I turn on the A/C the fans come on until it gets to 180, then fans shut off. Does it sound like the setting in the chip somehow got changed? Last week I replaced the 25 amp high speed relay with a 30 amp relay because the 25 amp relay kept blowing. Now I have this temperature issue. Are these problems related? When I removed the wire to the temperature sensor it got up to 210, reconnected the wire and the fans came on and it came back to 200. The water pump was replaced about a week ago. Could it be faulty? Any ideas? Thanks!
