- May 26, 2001
Why is it that owners complain about a vacuum system will not allow enough boost when launching?
It is the same pads and brake shoes as the PM or other assist since you apply the brakes BEFORE you get into boost.
The most common issue like you have is the torque converter is not matched to the turbo.
Just this year so far I have already changed one converter for a 60mm turbo, one on the lift now getting a new 3600 stall converter, and one waiting for a new converter.
This is the most common performance issue the turbo cars I deal with that have been built elsewhere, and with the proper converter, the car then performs like it should.
Most of the converters I replace are non-lock up as it will spool much better.
I have been doing these cars for years and hear lots of comments about top end slippage with a loose converter, but street or strip, the car that leaves the best is usually the winner as MPH does not win a race, getting there first does!
In your case with a 60mm turbo, I just installed a 3300-3400 converter in a GN last week, and it is awesome.
