I've been having troubles gettin my car started with my new bank to bank speedpro system on it. I've had it running before and had one day of tuning on it while sitting in the garage a couple months ago. Now that it's cold out (30 degress) it won't start. I've changed the cranking fuel...the IAC start...everything. First off I better let you know it's a turbocharged firebird so i'm dealing with the GM HEI (external coil) ignition system. It's also got an msd 6a box and an accel supercoil on it. Last year i had DFI on it and I always noticed that it wouldn't actually fire WHILE i was cranking...it would just fire when i let off the key. Well, now since it hasn't been starting with the speedpro (once in a while it'll try to start when i let off the key but it doesn't) I took the coil wire off the distributor and put a plug in it to see if it was getting good spark. I unkhooked the injector harnass and proceeded to crank the engine while wathcing the plug. NO SPARK while cranking...NONE! THen i let off and it sparks once at the plug and at the same time I noticed an arc from the positive post on the coil to the wire boot. I kept trying it and it does this every time. There's no spark until i let off the key. Just wondering if someone could please help me out. I can't figure out why in the world this is happening. It's driving me crazy I wouldn't think the msd box would be bad or the coil b/c when that stuff goes bad it usually just quits working. I can't think of anything. I know it would start if i had spark during cranking (that always seems to help
Thanks for the help in advance!
