Hawaiian Turbo
POWER'D BY BUD LIGHT
- May 25, 2001
I have an 86 T and installed a turbo'd SBC. Car was running fine, then all at once AF went to high 9's to 10. After that I had to turn off the fuel pump until it started, then turn it on. Now won't start at all. Seems like the FAST is pulsing the injectors all the time. I can hear the MSD box beeping and I felt the injectors, they're pulsing along with the beep. Took out the 83's to see if it was a stuck injector, same results with the 42's. After I turned the fuel pump off, it used to hold pressure, now it goes straight to zero. Pulled plugs and they're all wet. One time even had flames coming out of the downpipe while trying to start. Think I should send the box back to have it checked? Any ideas??
Thanks, Paul
Thanks, Paul
