I had a couple of problems with it.
1. The drain valve is so far over to the side it cannot be opened it hits on the frame side. The only way I can drain it is to remove the lower hose.
2. The radiator is so wide(which is a good thing) I had to file down the welds to get it to fit in the car.
3. The lower oil fitting bung is welded in at an angle, not straight. So the factory oil line fitting won't go in, the frame is in the way. In other words I still can't drive the car tommorow I have to get a new hose made with a 45 degree fitting.
4. One of the fittings for the Engine oil cooler had no threads in it. It has the threads to thread into the radiator but not for the hose.
I'm not saying I want my money back okay. I'm not pissed, a little upset but hey things happen with custom built products.
For Over 600 dollars it should fit no problems. I have to buy a new hose, a fitting, etc.
NEWEST PROBLEM
THE DRAIN PETCOK BUNG IS LEAKING ALL OVER THE PLACE IT'S NOT COMPLETELY WELDED IN. So know it has to come out again be repaired or finished whatever you want to call it.
This radiator has had to come out 5 times for one reason or another.
RESPONSE FROM TONY===== NONE HE DOESNOT CALL ME OR E-MAIL ME BACK HAS ANYBODY ELSO HAD PROBLEMS WITHA RADIATOR.
NEWEST PROBLEM
