- Jun 18, 2001
I will be in Bowling Green this year and can bring these or ship them if you like.
CAS V4 has some damage from loading on a trailer which caused the IC to hit the fan. All cosmetic and it happened years ago and the IC was on the car up till last week. I have all the mounting hardware needed to install it. $400
Razors Twin Nozzle Alky kit. It has been on the car for awhile but has had very little use. Kit is complete and in good shape. The one short hose on the inlet pipe will need to be replaced I inadvertanly shorted it out on the battery which melted a hole in the side of it. Also one of the coolant tank brackets snapped when I was removing the system. I am however going to include the Aluminum inlet pipe with the nozzels mounted along with an IAT sensor. The kit is complete.
This is a practically new Walbro 340 fuel pump and factory hanger for a standard dash. $150
